Thicken fails on loft surface.
diogo_neves308
Member Posts: 5 ✭
in General
I'm trying to thicken a loft surface and it keeps failing, I think its a shape problem, but i have no clue how to resolve it.
Thanks for the help.
https://cad.onshape.com/documents/3606771a0cdefc466f40b52a/w/f0c938407de46ec7a7ca075e/e/47df54e87611e93840d61a7b
John_P_Desilets
Onshape Employees, csevp Posts: 273
Thanks for sharing @diogo_neves308. The surfaces in your example have a few areas that will cause the thicken operation to fail.
Tight corners or faces that change direction dramatically will cause the thicken to fail. Below is an image of a surface before and after a small thicken operation.
The lofted surface needs to be smoother in order for the thicken feature to work. You can try to add fillets to remove the sharp edges but that will only solve a portion of the problem. I think the best thing to do would be to go back and adjust the sketches to form a smother surface. You can also try adding 3D curves to help drive the shape of the surface.
