Gear Relation for Internal Gear aka Spirograph
geoff_higginbottom
Member Posts: 8 ✭
Hi Team,
I have developed a SpiroGraph that has an adjustable outer ring which auto generates the gear teeth depending on ring size which works great. However I cannot work out how to animate the rotation of the 'Spiral' Disc within the outer ring.
I have watched this tutorial https://cad.onshape.com/help/Content/materelation-gear.htm but it does not help as I cannot work out how to place the Revolute Mates.
I want the inner disk to move around the outer ring, which I can do using a Tangent Mate, but I also want it to rotate as though the gears were meshing and making it rotate.
Here is the link to the document https://cad.onshape.com/documents/a7d99d6fd77f3294449b23d2/w/856a3f5fad3c42ab9a79fd16/e/a6e7f9715e7b65f03cce206d
MichaelPascoe
Member Posts: 2,686 PRO
Here is an approach that you could take:
Spirograph - MP- Apply the mates to the parts before you place them into the assembly.
- Create another part concentric with the inner gear.
- Use two revolute mates. One for the inner gear to rotate around the larger gear, and the other to spin the small gear.
- Then use the gear relation to connect the two revlute mates.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴2
Spirograph - MP
