"normalize" documentation
brooke_spreen
Member, Developers Posts: 115 ✭✭✭
It looks like the documentation for the function "normalize" has been updated recently. I find it rather difficult to interpret.....if I had not used it several times in the past, it would be difficult to figure out which function would give me the Direction of a vector. This could maybe use some clarification? Perhaps "returns Direction" instead of "returns Vector" in the first line of documentation?
Design Engineer | Anerdgy AG
The normalize function does not give you the "direction" of a vector, a vector is a direction. The resulting vector is in the same direction, but the magnitude is 1 (unitless).
Normalizing is a common mathematical term, just as dot product and cross products are.
Types such as "line" specify direction to differentiate between the two vectors in the definition, one for a point and one for a direction. Both are vectors that could be normalized. Vector is the data type, direction is the purpose.
is3dDirection (value) predicate
True for a unitless 3D
Vectorthat is normalized (i.e. has length1)EXAMPLE
