How should I reference each body made by a pattern
jason_1
Member Posts: 30 PRO
I'm trying to make a sample featurescript where a body is patterned and each body created by that pattern is set to a different color.
I've successfully done the similar thing by creating the bodies within a for loop that also sets their PropertyType.APPEARANCE.
And I've successfully gotten the bodies to patten using curvePattern(), but when I try to set their colors I end up coloring all the bodies made by that pattern at once.
What's the best way to reference each instance of the body created by a pattern? Is there some attribute I should be calling? Or some way to put them all into an array?
I'm also reading now about forEachEntity() and wondering if this is actually the function I should be using somewhere
qNthElement(qCreatedBy(id, EntityType.BODY), i) will work by virtue of pattern instances being internally processed in the correct order. It might be more convenient to use qPatternInstances query. forEachEntity processing is not useful in this case - it would be if you wanter to make geometry changes on each entity separately. E.g. if you wanted to hollow patterned parts with thickness depending on i.
