I need to import a dwg/dxf logo into my model and do a cut extrude. Is this possible in OS?
carlos_cruz
carlos_cruz Member Posts: 1 ✭
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,483 PRO
    Currently no, it is often asked feature so I would guess it will be implemented at some point.
    See help for more details:
    For Part Studios:
    Onshape can write Onshape Part Studios to:
    Onshape can read Part Studios from:
    • Parasolid
    • ACIS
    • STEP
    • IGES
    • SolidWorks
    • Parasolid
    • ACIS
    • STEP
    • IGES
    • CATIA v5
    • SolidWorks
    • Inventor
    • Pro/ENGINEER, Creo
    • JT
    OpenFor Assemblies:
    Onshape can write Onshape Assemblies to:
    Onshape can read Assemblies from:
    • Parasolid
    • STEP
    • Parasolid
    • ACIS
    • STEP
    • IGES
    • SolidWorks Pack and Go files
    • JT
  • r_paul
    r_paul Member Posts: 22 ✭✭
    @carlos_cruz
    Do you have access to a person with AutoCAD?  If you do and have the .dwg/.dxf file they will be able to open the file and export it in either acis or step formats and then you can do the rest with Onshape.
  • lougallo
    lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,020 image
    @carlos_cruz Currently we do not import DXF/DWG in as sketches but I have added you to the improvement.
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • onshaper
    onshaper Member, Mentor Posts: 99 ✭✭✭
    Hey r_paul, how does this work? Just trying to get simple text onto a face!
  • james_75
    james_75 Member Posts: 1 ✭
    Add me as well to this improvement as well please. DXF import would make marking items easier. Logo, Part ID #, etc.
  • keppel
    keppel Member Posts: 7 ✭
    please add me to the improvement.
