A teacher is getting the message, "web gl rendering context has been lost." Any ideas to fix this?
Not sure how this could be resolved.
  • Domenico_DiMareDomenico_DiMare Member, Onshape Employees Posts: 88 image
    @robert_wankmuller
    This is often an issue between the browser and the graphics driver on your device. Make sure both are updated. There may also be browser extensions that are interfering. You can try disabling the extensions.
    Here's a link to Onshape's Help Content about Web GL: https://cad.onshape.com/help/Content/webgl.htm#WebGL
    Please try making sure WebGL is turned on and hardware accelerated.
    If you are still having issues after following the steps in the above link, please provide some more info about what browser you are having issues with. You can also reply with a screenshot of this browser check: https://cad.onshape.com/check
