Is it possible to do a fly through in Onshape?
derek_westwood
Member Posts: 34 ✭✭
To do this, you would need to place your parts in an assembly. Then create a continuous "path", surface or part, for the assembly to follow, this would be grouped with the parts you wish to fly through. Then, have the whole assembly follow the fixed "camera" that is attached to the path. If this were a room, the room and path would move while the "camera" part would stay still.
If you would like to do this, I can make an example to show you, but it is not a simple set up.
RENDERCAD
