Can anyone help me understand how to fillet the edges connecting revolve to the Main Body&Half Globe
I'm not sure why these two edges cannot be filleted? Thanks!
BenTaylor Member Posts: 48 PRO
The edges I think you're trying to fillet end in vertices with zero thickness. Onshape doesn't know how to interpret that. You could use a variable fillet and set the radius at each end to 0.
Here's an example (that builds your part much faster as well):
https://cad.onshape.com/documents/373c41515de22609937555e5/w/dc4dea711523077f334f0952/e/13a5dfb7a025348ba85abae3
Ben Taylor
Lead Mechanical Engineer @ Healing Innovations0
