Pre selection logic?
MichaelPascoe
Member Posts: 2,635 PRO
I'm having trouble understanding how to export a function. Can someone give me some pointers?
Here is what I'm trying to do:
If you have pre selected a plane and a vertex, then click the feature, the feature will detect that you are wanting to use the "Up to vertex" method. I'm trying export these definitions so that the interface will show you what has been selected. When I'm not trying to export the definitions, the code works great, but I wan't the user to see which method is selected.
A summary of my attempt:
https://cad.onshape.com/documents/bdffe7bf48f3b4155e85d073/w/4aa864c3858500b61d8570f5/e/433e168b78be95d2d6e248ec
annotation { "Feature Type Name" : "Section", "Auto Section Function" : "autoSection"}
export const section = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Plane or face", "Filter" : GeometryType.PLANE || EntityType.VERTEX, "MaxNumberOfPicks" : 2 }
definition.rootPlane is Query;
//Required to create a drop down menu.
annotation { "Name" : "Section method" }
definition.sectionMethod is sectionMethod;
if (definition.sectionMethod == sectionMethod.UPTOVERTEX)
annotation { "Name" : "Up to vertex", "Filter" : (EntityType.VERTEX), "MaxNumberOfPicks" : 1 }
definition.limitEntity is Query;
export function autoSection(context is Context, id is Id, oldDefinition is map, definition is map) returns map
if (oldDefinition != {}) // Only do anything on preselection
return definition;
//When I'm not trying to export, the following logic works great.
if (size(evaluateQuery(context, definition.rootPlane)) == 2)
const autoVertex = qEntityFilter(definition.rootPlane, EntityType.VERTEX);
const autoPlaneOrFace = qSubtraction(definition.rootPlane, autoVertex);
if (size(evaluateQuery(context, autoVertex)) == 1 && size(evaluateQuery(context, autoPlaneOrFace)) == 1)
definition.sectionMethod = sectionMethod.UPTOVERTEX;
definition.limitEntity = autoVertex;
definition.rootPlane = autoPlaneOrFace;
return definition;
Alex_Kempen
Member Posts: 255 EDU
Wait, really? IIRC, there should be an option to mark a post as an answer if you've created the question. Maybe I'm wrong though?Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots0
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/577e2aaf45a542f98d9343c7
Onshape, Inc.
annotation { "Feature Type Name" : "Section", "Auto Section Function" : "autoSection"} export const section = defineFeature(function(context is Context, id is Id, definition is map)It seems you've accidentally written "Auto Section Function" instead of "Editing Logic Function", so your editing logic function isn't actually running.As a side note, one common technique I like to use when troubleshooting code is to insert print statements into sections of the code. I find this very helpful for troubleshooting since it can quickly tell you if a part of your code is actually running (but not behaving properly), which can help rule out possible issues. You can also print out values to see what information your FeatureScript is actually processing.
Edit: I had a brainfart and forgot how isCreating works. If you don't include it, the editing logic function only runs when a feature is created (i.e. before you click the checkmark once). Otherwise, the editing logic function will always run, regardless of whether the feature has been saved or not.
I can't go back and update "yes" this answered my question. If you post it again, I will click accept the answer, for the record.
