Pre selection logic?
MichaelPascoeMichaelPascoe Member Posts: 2,689 PRO
edited March 2021 in FeatureScript
I'm having trouble understanding how to export a function. Can someone give me some pointers?
Here is what I'm trying to do:
If you have pre selected a plane and a vertex, then click the feature, the feature will detect that you are wanting to use the "Up to vertex" method. I'm trying export these definitions so that the interface will show you what has been selected. When I'm not trying to export the definitions, the code works great, but I wan't the user to see which method is selected.
A summary of my attempt:
https://cad.onshape.com/documents/bdffe7bf48f3b4155e85d073/w/4aa864c3858500b61d8570f5/e/433e168b78be95d2d6e248ec
annotation { "Feature Type Name" : "Section", "Auto Section Function" : "autoSection"}
export const section = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Plane or face", "Filter" : GeometryType.PLANE || EntityType.VERTEX, "MaxNumberOfPicks" : 2 }
        definition.rootPlane is Query;
        //Required to create a drop down menu.
        annotation { "Name" : "Section method" }
        definition.sectionMethod is sectionMethod;
        if (definition.sectionMethod == sectionMethod.UPTOVERTEX)
            annotation { "Name" : "Up to vertex", "Filter" : (EntityType.VERTEX), "MaxNumberOfPicks" : 1 }
            definition.limitEntity is Query;
export function autoSection(context is Context, id is Id, oldDefinition is map, definition is map) returns map
    if (oldDefinition != {}) // Only do anything on preselection
        return definition;
    //When I'm not trying to export, the following logic works great.
    if (size(evaluateQuery(context, definition.rootPlane)) == 2)
            const autoVertex = qEntityFilter(definition.rootPlane, EntityType.VERTEX);
            const autoPlaneOrFace = qSubtraction(definition.rootPlane, autoVertex);
            if (size(evaluateQuery(context, autoVertex)) == 1 && size(evaluateQuery(context, autoPlaneOrFace)) == 1)
                definition.sectionMethod = sectionMethod.UPTOVERTEX;
                definition.limitEntity = autoVertex;
                definition.rootPlane = autoPlaneOrFace;
    return definition;
  • Alex_KempenAlex_Kempen Member Posts: 258 EDU
    Wait, really? IIRC, there should be an option to mark a post as an answer if you've created the question. Maybe I'm wrong though?
    I dont know the answer here but it may be worth looking at the bottom of the Plane source code to see how we use editing logic to change the feature based on preselections:
    https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/577e2aaf45a542f98d9343c7
    Onshape, Inc.
  • MichaelPascoeMichaelPascoe Member Posts: 2,689 PRO
    That is what I have been referencing, but I still don't seem to have it down.
    edited March 2021
    From a quick glance at your code, it seems you're not actually defining your editing logic function properly in your feature definition.
    It seems you've accidentally written "Auto Section Function" instead of "Editing Logic Function", so your editing logic function isn't actually running.
    As a side note, one common technique I like to use when troubleshooting code is to insert print statements into sections of the code. I find this very helpful for troubleshooting since it can quickly tell you if a part of your code is actually running (but not behaving properly), which can help rule out possible issues. You can also print out values to see what information your FeatureScript is actually processing.
    Edit: I had a brainfart and forgot how isCreating works. If you don't include it, the editing logic function only runs when a feature is created (i.e. before you click the checkmark once). Otherwise, the editing logic function will always run, regardless of whether the feature has been saved or not.
    @Alex_Kempen That did it. Thank you!
    I can't go back and update "yes" this answered my question. If you post it again, I will click accept the answer, for the record.
    edited March 2021
    There is, but I clicked no too soon... I made a typo when trying what you said, your answer worked perfectly.
    Also, @TimRice, your answer was good too, I appreciate the pointers!
