How do I extrude a shape?
meg_brown
Member Posts: 10 EDU
Hi there.
I am having trouble extruding my shape. I drew it up on adobe illustator and then have exported it as a dxf file on onshape. The shape is grey, but it still won't allow me to extrude the shape as there is 'input' issues. What am I doing wrong?
I would be super grateful for some help!!
My current solution is:
RENDERCAD
Thanks for replying,
I have traced it as you can see above, but I still getting the same issue- it is 'degenerate'
How do I fix this??
Also, it looks like you may have used one long spline with lots of points. I also used to do this, and sometimes still do. This can cause it to fail. Try using as few of spline points as possible. This will reduce the failure rate, and give you a smoother looking spline.
RENDERCAD
Here is a way to narrow the search quickly - called 'binary search' by the gurus. See the thread here.
I was thankful for hearing about it from an Onshape engineer; Sorry I forgot who first posted it but I am happy to share it when the question comes up. Really is slick until a tool is available to auto find/fix...
