I cannot see the assignments from my class
I am part of the Team: NHS DDP Period 1. But none of the assignments are populating on the Team's list.
    Ste_WilsonSte_Wilson Member Posts: 208 EDU
    If you are setting up the teams you need to make sure you are a member of them as well to see what's in them.  (I fell foul of this!).
    You haven't given much information to help us help you :)
    Domenico_DiMareDomenico_DiMare Member, Onshape Employees Posts: 85
    @Ste_Wilson had a good suggestion. I've definitely done that too!
    If his suggestion didn't help, It's also worth noting that only documents shared with the team will show up when you filter your documents by team. So if students haven't shared their assignment with the team, then they won't show up. Same with an assignment that your are giving students.
