Offset Issue
eric_borden595
Member Posts: 22 ✭
I have been working on this drawing: https://cad.onshape.com/documents/254de3cb7943e51f789a4ebb/w/bcf9f589e3aaece018525e29/e/6793e296358d8401df5d22f1
Please don't judge my drafting capabilities as I fully admit, I don't have any!
I'm trying to "Offset" the edges of my drawing but I'm having issues with red lines showing up once the Offest is created. I understand due to curvature, one can't easily offset the entire edge of the drawing so I did split it before I tried the Offset. If you look at my 2d sketch, I have created "pieces". If you look at the piece labled with "2" at the bottom left you will see the red line result I'm talking about. I have looked for what this red line means but can't find an answer.
If I try Offset on sections of the "mouth" and "eyes" I don't get red lines and it seems to work well. What did I do wrong with the outline of the tree that is keeping me from using Offset on even the smaller less curved segments?
Thank you.
Thank you.
Ste_Wilson
Member Posts: 533 EDU
If you're getting 'red' lines that means something is over-constrained, for example, you have said line a is equal to line b AND you have dimensions on both lines. The dimension on line b is not needed. Christmas tree looks good
I thought, hey, lets copy the split segment and paste it back in and try to offest that. Interestingly, I got the segment I split and all the spline handles for the entire tree outline when pasted. This makes me think the offset is failing because it is actually trying to offset the entire spline, not just the segment I split.
There are some things that don't offset well such as my example using a spline. OS can't keep up with the math for this or is trying to loop back on it's self.
Sketch 1 works ok but sketch 2 gives this message.
