Section View? - Android
MichaelPascoe
Member Posts: 2,814 PRO
I'm having trouble finding the section view button inside the android Onshape app. If the document is view only, there is a view only menu that has a section view which works. Is there a way to manually bring up the view only menu so that I can section view?
RENDERCAD
MichaelPascoe
My co-worker figured it out:- Select a planar surface
- Tap the view cube
- Scroll down, section view will be at the bottom of the list
RENDERCAD
________________________________________________________________________0
- Tap the view cube
For others using the mobile app, two finger tap is the right click equivalent.RENDERCAD
