Tabs in sheet metal
Mark_Bantle
Member Posts: 2 EDU
I am trying to do a project with my students where they design packages for products. I have used the sheet metal tool and seen about adding tabs, but we keep running into an issue. If I create a cube (for example) and create the sheet metal feature to enclose it, with bends, we can see the flat view of the package. When I try to add tabs to the sides that meet, (in order to glue the sides together) I can only put two tabs on a side. Adding a third tab to the side that is the last to close on a simple box gives me (and my students) and error.
Is there a secret to this? Or a better way?
I want my home bound students to create models at home, where all they have access to is paper.
Thanks for the help,
Mark
Mark
Hard to say without seeing what you are doing
https://cad.onshape.com/documents/e567435b5c310971ffed3d37/w/ede3ec84fc869dc0f9215ee4/e/d8cac2c84f7957a1e104bfc7
Twitter: @BryanLAGdesign
