Mirror Swept Cuts
Can OnShape mirror a swept cut to the opposite side of a part? The part was created with a midplane extrude so I would use the midplane as the mirror plane.
nav Member Posts: 258 ✭✭✭✭
Thanks @cyclonewade great workaround just tried it.Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions5
Right now Onshape is built for mirroring bodies. At some point down the road Onshape will probably be able to mirror features. Here is what I would do in place of a swept cut and mirror. Use the sweep and switch the option to "New". This creates a body. Use the mirror tool and mirror the body. Once you have two bodies that are mirrored, use the Boolean command and subtract the swept bodies from the main body. Wham!
Good Luck!
