Bug: Boolean subtract creates unrelated hole
Gunter
Member Posts: 8 ✭✭
Location: In my public document "AnycubicMegaS" in tab "Cable Chain Restricted Copy 1" at boolean subtract step "Boo-CEndTaps".
Problem: In addition to the intended 2 metric threads a small odd-shaped blind hole appears in the target object that is nowhere near the tools. If I suppress the nearer of the 2 taps the hole does not appear. I put a text label "Bug" next to the hole.
URL: https://cad.onshape.com/documents/889dcf492394f6c435f4f00f/w/a6c375f368428d17c02411db/e/5534c8880c837aa6f8369a2b
You can also try using a transform feature set to scale to increase the size of your part by some factor before you boolean it as well.
But that face is one that I need to offset, so I'm still stuck.
Scaling is not an option in this case because that would change the thread pitch.
What I'll try is revolving a chamfer around the ends of the tap; I assume there is something bad about how the thread runs out that sends an offset shard off to the side by more than the diameter of the tap. Still, I'm not convinced that this is correct behavior on the part of OnShape.
But I contend that this is a bug, caused by an algorithm that isn't quite complete, that doesn't take into account a corner case which I found with my tap. An "offset face" should never produce anything further away from the original geometry than the offset amount.
