How to correctly loft this profile
peter_paton
Member Posts: 43 ✭✭
Hi, I confess I asked this question a couple of years back but I have forgotten how this is done.
The issue is in getting the profile to render correctly a. without a twist and b. with the vertexes correctly aligning. From earlier comments I used curves as guides but I can't find the tutorial I followed on that occasion and so far I am beat as to how to get the profile correct. Any assistance will be greatly appreciated!
Hopefully the picture below makes it clear. Also check out Help Loft Point 8 instructs on Match Connections
See this copy of your doc for this example.
https://cad.onshape.com/documents/44300b8443e31a8a7552cb4e/w/9ece92663a727e60560de254/e/16bfe04dba93e1918d42c010
Look carefully at my second example, esp. the dialog box.. The purple lines are from Match Connection NOT Guides.
Read the help and practice, you will get it. Lofts have lots of options and requirements.
