C# OAuth sample stopped working
Michał_Wójcik
Member Posts: 13 ✭
I'm trying to run the sample at https://github.com/onshape-public/app-windows-sample and all I'm getting when I run it is an authentication error. I've set my project up on the developer portal and supplied the environment variables as described in the readme, and this is what happens after I run the sample:
I had a colleague try it to confirm it's not just me, he's having the same issue. Is there a solution? Did the API change to the point of this sample being obsolete?
