Is there a way to view past daily activity?
jenne_baker
Member Posts: 4 ✭
I am new here; I need to log my hours for a project and wonder if there is a way to see how many hours were spent in the learning center and or the documents?
In your document you can use the version history, each activity has a time stamp and a username attached to it
I recommend creating a version and call it clock in and then another called clock out until you find a better method
Not sure about tracking the learning center1 -
ok, I was hoping there would be something that I would be able to see especially when I'm in the learning center.0
Thank your for your help.0
