HOW TO CONVERT SURFACE TO SHEET METAL?
baldo_flores
Member Posts: 5 ✭✭
Does any one know how to convert a surface to sheet metal?
Optionsjohn_mcclary Member, Developers Posts: 3,900 PROIn whe sheetmetal feature choose the thicken option0
OptionsMBartlett21 Member, OS Professional, Developers Posts: 2,034 EDUAlternatively, the Convert option can be used if you want to use all faces of the surface.
The only surfaces supported are cylindrical, extruded, or planar.0
hey
what to do if I need to get a unfolder from a surface (single curvature)
the point is for my case the surface is not cylindrical or extruded, it is loft and single curvature and I need to get a unfolder
Then check out this resent custom feature from Konstantin
