HOW TO CONVERT SURFACE TO SHEET METAL?
baldo_flores
baldo_flores Member Posts: 5 ✭✭
Does any one know how to convert a surface to sheet metal?
  • john_mcclary
    In whe sheetmetal feature choose the thicken option
    Each surface face must be planar though. Trying to convert a curved surface will not work.
  • MBartlett21
    Alternatively, the Convert option can be used if you want to use all faces of the surface.
    The only surfaces supported are cylindrical, extruded, or planar.
    IR for AS/NZS 1100
  • baldo_flores
    thank you
  • Alexy_Kougerman
    Alexy_Kougerman Member Posts: 8 ✭
    hey
    what to do if I need to get a unfolder from a surface (single curvature)
  • Alexy_Kougerman
    edited April 2021
  • lana
    You can now convert cylindrical or extruded surface to sheet metal.
  • Alexy_Kougerman
    the point is for my case the surface is not cylindrical or extruded, it is loft and single curvature and I need to get a unfolder
  • lana
    @Alexy_Kougerman
    Then check out this resent custom feature from Konstantin
  • Alexy_Kougerman
    edited April 2021
    thanks a lot @lana
    I have already contacted @konstantin_shiriazdanov and received help, it is seems to me he is a magician and a wizard...  ;)
    the FS unwrap ruled segment is that I need
    by the way the sheet metal model (fot default inerface) is a good feature, but it does not desire to know conic surfaces unfortunately
