Form a Part to a Curve?
Sky777Sky777 Member Posts: 6 EDU
edited May 2021 in Using Onshape
I am creating bristles for a roller brush, and I need to be able to form the Part shown below (Part 2, the toothed Part) to the curve shown below (Curve 1, The Helix) I cannot find a tool to do this. The main reason I need to do this is to be able to make the Part look correct in an assembly in OnShape, so if there is a way to do this in the Assembly tab, then I will do that instead. I cannot find a way or tool to do either. Is there perhaps some way to bend the Part?
  • Alex_KempenAlex_Kempen Member Posts: 252 EDU
    You're not going to be able to bend the existing part onto the curve, but you should be able to model the brush following the path of the curve fairly easily. Start by sweeping a sketch profile of the main body of the brush along the curve, then use a curve pattern to pattern a single bristle along the helix as well.
    The Sweep feature help page
    The Curve pattern feature help page
  • shawn_crockershawn_crocker Member, OS Professional Posts: 900 PRO
    I would try searching for a custom feature.  There are people doing some amazing work with featurescript and I am constantly amazed at the extra functionality that is just waiting to be used, offered up by wonderfully open, smart and sharing individuals.
  • Sky777Sky777 Member Posts: 6 EDU
    @shawn_crocker Ok, Thank you very much! I have found some great custom features, I just don't know what to search for on this one. Will continue looking. Thanks for your input!
    @Alex_Kempen Thank you! I am not quite sure what you mean by using a curve pattern to pattern a single bristle, though. Could you expound upon that statement? Thank you very much for helping! :)
  • MichaelPascoeMichaelPascoe Member Posts: 2,478 PRO
    edited May 2021
    Like @Alex_Kempen said, Curve pattern will work well for this.
    Try something like this:
    • Sweep the profile you want along a curved path (Make sure the profile is normal to the path)
    • Extrude a single bristle template at the start of the path.
    • Curve pattern remove the bristle template along the path (I extended the path by one bristle with Extrude so that the curve pattern will not end on an empty space)
    https://cad.onshape.com/documents/acd30775f1fefc24c74eb340/w/5daa7369b967b85a76dfff92/e/5809ca462f0b6a94ebe96528
    @MichaelPascoe Wow, thank you! I did not think of this before. I will use this method. Thank you very much! :)
