Help with for loop and incrementing variable
mason_weaver
Member Posts: 6 ✭
I'm trying to write a script that will help make a crankshaft. It is supposed to take a basic unit of the crankshaft, translate it (and copy it), then rotate it. Then it will repeat the process until it has satisfied the proper number of segments. Here is what I'm having trouble with right now:
for (var i = 1; i < definition.instances; i += 1)
linearPattern(context, id + "linearPattern" + i, {
"patternType" : PatternType.PART,
"entities" : definition.startBody,
"directionOne" : definition.frontFace,
"distance" : (movement.distance * i),
"instanceCount" : 2,
"oppositeDirection" : true,
"operationType" : NewBodyOperationType.NEW
opTransform(context, id + "transform" + i, {
"bodies" : qCreatedBy(id + "linearPattern" + i, EntityType.BODY),
"transform" : rotationAround(rotationAxis, definition.twist)
It works like it should with only the linear pattern, but once I add the rotation, it doesn't work. It worked before I added the loop, without "i." What do I need to change to get "bodies" under opTransform to query the body created by the linearPattern? 0
Alex_Kempen
Member Posts: 258 EDU
Addressing your specific question, the reason why your code no longer works when you add the rotation to the for loop is because your ids have an invalid structure, which causes them to fail when you have more than one operation in the for loop. Instead of writing your ids as id + "yourName" + i, write your ids like this: id + ("yourName" ~ i)
It also looks like your for loop might be terminating an instance too early. Try making your stop condition (the middle statement) i <= definition.instances, or start with i = 0 instead of i = 1.
As an added bonus, here's how you can condense what you're trying to do to a single opPattern operation. opPattern is actually a lot like opTransform, except it copies instead of patterning. By stacking your transforms correctly, you can bypass the need for the linear pattern feature.// get the plane represented by your plane const evalautedPlane = evPlane(context, { "face" : definition.frontFace }); // set the direction based on the normal of the plane and the state of definition.flipDirection (which you should add) const direction = definition.flipDirection ? -evaluatedPlane.normal : evaluatedPlane.normal; // start your for loop from zero; it makes indexing into an array possible for(var i = 0; i < definition.numInstances; i += 1) { // multiply your transforms together to apply them one after another (from right to left) const computedTransform = rotationAround(rotationAxis, definition.twist) * transform(direction * distance * (i + 1)); // opPattern is like opTransform, but it also takes an instanceNames argument and does our copying for us, too opPattern(context, id + ("linearPattern" ~ i), { "bodies" : definition.startBody, "transform" : [computedTransform], "instanceNames" : ["pattern"] }); }Lastly, feel free to take a look through some of the heavily annotated FeatureScript examples I have which can be found here. I hope some of this helps!Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots1
// get the plane represented by your plane const evalautedPlane = evPlane(context, { "face" : definition.frontFace }); // set the direction based on the normal of the plane and the state of definition.flipDirection (which you should add) const direction = definition.flipDirection ? -evaluatedPlane.normal : evaluatedPlane.normal; // start your for loop from zero; it makes indexing into an array possible for(var i = 0; i < definition.numInstances; i += 1) { // multiply your transforms together to apply them one after another (from right to left) const computedTransform = rotationAround(rotationAxis, definition.twist) * transform(direction * distance * (i + 1)); // opPattern is like opTransform, but it also takes an instanceNames argument and does our copying for us, too opPattern(context, id + ("linearPattern" ~ i), { "bodies" : definition.startBody, "transform" : [computedTransform], "instanceNames" : ["pattern"] }); }Lastly, feel free to take a look through some of the heavily annotated FeatureScript examples I have which can be found here. I hope some of this helps!FRC Design Mentor - Team 1306 BadgerBots
Also, would you be able to point me in the direction of merging the created bodies into one, possibly with opCreateCompositePart, or with NewBodyOperationType.ADD?
// maybe make this optional and/or check if the input tools are empty opBoolean(context, id + "boolean", { "tools" : qCreatedBy(id, EntityType.BODY)->qBodyType(BodyType.SOLID), // can also qUnion with input part, if desired "operationType" : BooleanOperationType.UNIONTo check if it is the transform which is failing, you can try adding an "is transform" check to your computedTransform declaration. You could also replace the transform with identityTransform() to see if it fixes your problem, which would also mean it is in fact an issue with your transforms.
I might have some theories as to why your transform might be failing, but it's hard to say without seeing your entire code. Is there any chance you could make your document public and post the link here?
Here is what I have so far
const patternId = id + "pattern"; for (var i = 0; i < size(numPattern); i += 1) { /** Each opPattern has ids as follows: * id + "pattern" + "pattern0" * id + "pattern" + "pattern1" * id + "pattern" + "pattern2" * etc. * Since ids are hierarchical (i.e. like a tree): * Both qCreatedBy(id, EntityType.BODY) and qCreatedBy(id + "pattern", EntityType.BODY) return all bodies created by the pattern. */ opPattern(context, patternId + "pattern" ~ i, { "bodies" : definition.startBody, "transform" : computedTransform, "instanceNames" : ["pattern"] }); }<br>FRC Design Mentor - Team 1306 BadgerBots
