Different Languages in "Text" option
dylan_dodylan_do Member Posts: 2
I am working on a Chinese chess set and thought it would be extremely easy if I could just type in the characters for the respective pieces and extrude them.
Onshape appears to not recognize the character and instead shows a blank rectangle
I'm sure that this is not an intended function in Onshape, but I might as well just put it here just in case.
  • Alex_KempenAlex_Kempen Member Posts: 254 EDU
    It seems like the text feature supports all kinds of language, but the font you choose has to support your desired language.
