Extrude a inclined surface
Kai_himself
Member Posts: 43 ✭✭
Good morning,
i need your help once more. I would like to extrude a inclined surface in a round object.
Here is a drawing by paint. I hope you can see the inclined surface (red lines).
At the moment the bottom is flat (yellow lines)
I tried it, with two 3d splines at the right side, and with the loft feature, but it didnt work.
Is it possbile to extrude the bottom surface inclined ?
Edit: I forgot the link: https://cad.onshape.com/documents/96d666ac5e71edef3d9c33fd/w/0215f2b4676e093870b7b6ad/e/8681b96c0a0f498fa1d87e24
Best reagards
Kai
