Improvements to Onshape - May 7th, 2021
Lindsay_Early
Member, Onshape Employees, Developers Posts: 26
May is here and we’re kicking off this month with an update! This release has a lot of exciting new drawing improvements. Let’s take a look!
CAD IMPROVEMENTS
FULL ROUND FILLET
The fillet tool has been improved to create full round fillets.
DRAWING IMPROVEMENTS
DATE FORMAT IMPROVEMENTSOnshape added support for dd-mm-yyyy, d-MMM-yyyy, dd/mm/yy, dd/mm/yyyy, dd.mm.yy, and dd.mm.yyyy in drawing notes and the revision table.
DEFAULT OPTION FOR VIEW SIMPLIFICATION
A new default option for view Simplification has been added to drawings. You can choose from None, Absolute, Ratio to studio, Ratio to part, and Automatic. For best performance, it is still recommended to leave it on Automatic unless it is necessary to change it.
DETAIL VIEW IMPROVEMENTS
You can now show/hide sketches in detail views.
GENERAL IMPROVEMENTS
COPY LINK FROM DETAILS PANEL
The Details panel has been improved to include a direct link and copy link as a part of the Document Title.
EXPORT RULE IMPROVEMENTS
Export Rules have been expanded to be more versatile. Export rules now include Part Studio properties. They also trigger when exporting a face or sheetmetal flat pattern. Additionally, for Enterprise and Professional, Export Rules can reference the referenced part properties.
MOBILE IMPROVEMENTS
ANDROID ASSEMBLY CONFIGURATIONS
Android now supports changing configurations within an assembly.
ANDROID AND IOS WHERE USED FOR ENTERPRISE
Enterprise users can take advantage of Where Used with Android and iOS apps.
ENTERPRISE IMPROVEMENTS
RELEASE CANDIDATE ALIASES
Release Management is now improved with the use of Aliases.
CLASSLINK SSO
ClassLink has been added as an SSO provider for Onshape. To set it up, follow the directions in the Help.
LEARNING CENTER IMPROVEMENTS
ONSCALE TRAINING
We’re excited to announce that Onscale, creators of the cloud connected simulation app, have created the Onscale Solve Simulation Fundamentals training course in the Onshape Learning Center. This new course has 4 sections, 11 lessons, 2 exercises, over 2 hours of video.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Thanks Onshape team!
RENDERCAD
Onshape is beginning to capture the big picture better than any previous CAD system.
Представьте себе куб, и что выбрана одна грань. Есть два варианта как её скруглить. Поэтому и нужен дополнительный выбор.
Thanks for adding the option to turn off view simplification. (I would rather take a performance hit than NOT HAVE MY PARTS ON THE DRAWING)
With plenty of frustration I wen't to create improvement request for simply selecting only parts in part studio similar to what box or click select does in assembly workspace. IR can be voted here: https://forum.onshape.com/discussion/16159/select-only-parts-mode-in-part-studio
There are several combinations possible with the same central face. The right-most image is a surprising result. Here the side faces are not opposite but adjacent.Cough... wrap solid parts, cough...
RENDERCAD
There are lot of areas that require redundant data entry - I will stick to manually editing the file name, I guess
