How do I reference a body after a BooleanOperationType.SUBTRACT_COMPLEMENT operation?
It seems like the first time I perform a boolean op on something, I loose the ability to query it anymore. I thought this was what qCreatedBy() was for, but I can't seem to get that working either. It seems to return either nothing or, in the case of a union, some new points and edges that belong to the body I'm interested in.
In the included version, I can get the behavior I want, except that when I use the subtract complement functionality, I can't get the result to be applied to the original object, it ends up in a new object. Without that extra operation, it just modifies the original body, which is what I want. The problems start around line 95. Specifically, I don't understand why the debug statements at 109 and 110 come back empty.
See: https://cad.onshape.com/documents/811a3cd3b3c20b703ec44a95/v/a3517234f59dc4300c978185/e/a9198342824bf38f7fdfd502
Alex_Kempen Member Posts: 251 EDU
Okay, if I'm understanding your code correctly, you're making a copy of the result of extruding your feature, subtracting the complement of that result from the original feature, then merging that back into your original part.
Adressing your issue directly, the first thing worth noting is that qCreatedBy won't work on a subtract complement boolean feature since the boolean doesn't actually create anything, only modify existing geometry (qCreatedBy will, however, work with boolean types like boolean union).
The second part of your question revolves around the loss of the target. As you noticed, the query for your originalObj works fine before booleaning, but not after. This is because the opBoolean subtract complement feature is a subfeature which changes originalObj in such a way that the original query no longer works. Fortunately, this can be easily handled by using startTracking to create a tracking query before booleaning. The query created by startTracking should then resolve to originalObj as expected, even after booleaning.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots0
