How do I make a spiral?
Andrew_Gullo
Member Posts: 4 ✭
How would I go about making a spiral and what would be the best tool?
MichaelPascoe
Member Posts: 2,687 PRO
Here is how you can do it manually:
https://cad.onshape.com/documents/8cb905126d7cad709d946348/w/c207a83647d5d5c0e3c7e60d/e/fa3c4fa3552b9217e0986d02
Here is a custom feature I made a while back that will create them for you:
https://forum.onshape.com/discussion/14570/new-custom-feature-spiral
How to add custom features to your tool bar:
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
However, I realized that the built-in Helix does a fine job too, using a working conical body and an extra step of making a separate spiral sketch.
You can make a conical body (revolve or drafted extrude feature) and select the conical face when creating a Helix. Note: the height of the cone may not matter at all for your application, but the differnence in diameter between the bottom of the cone and the top of the cone can be used to control the "OD" and "ID" of your spiral.
Then you can create a sketch on a plane, and USE EDGE to copy the helix to the sketch plane:
Then you can hide the helix and the working body (or delete them with a delete feature) and you have a spiral, ready for other operations:
You can use the geometry of your conical body, and the definition of the helix to have good control over your resulting spiral.
Hope this helps!
Romeo
