Prevent selecting origin point in Featurescript entity parameter
George_Anderson
Member Posts: 71 ✭✭
Is there a way to prevent the origin point from being selectable in a Featurescript entity parameter, while allowing other points created by opPoint to be selectable?
Roughly, I have a set of features where the user adds "points", manipulates them over the course of several features, and then I use them to generate a geometry. I create point objects with opPoint, and then I want these specific objects to be selectable in later features. When one of these points is coincident with the origin (which happens naturally in virtually every model), the origin always remains the top-most selectable object, and you have to know to right-click, "select other" to correctly select the special object.
One obvious but expensive way around is to always do evVertexPoint on every selection and see if it's at the origin, but I was hoping there might be a more logical/attribute based way.
www.virtualmold.com
export function myEditLogic(context is Context, id is Id, oldDefinition is map, definition is map, isCreating is boolean) returns map { if (oldDefinition.myQuery != definition.myQuery && size(evaluateQuery(context, definition.myQuery)) > size(evaluateQuery(context, oldDefinition.myQuery))) { const addedEntity = qSymmetricDifference(definition.myQuery, oldDefinition.myQuery); if (evaluateQuery(context, qIntersection(qCreatedBy(makeId("Origin")), addedEntity) != []) { try { const point = // query for the point, using qHasAttribute->qContainsPoint->qNthElement or some other method definition.myQuery = qUnion(definition.myQuery->qSubtraction(addedEntity), point); } } } return definition; }<br>If you do go this route, I would also check if definition.myQuery contains the origin in the feature body, and add an appropriate warning for that case as well.FRC Design Mentor - Team 1306 BadgerBots
