Finding the latest release of a drawing
Please help me out - I am sure there is a better way. Now that I am far enough along the Onshape journey to be releasing drawings, I notice that as soon as I release a drawing, Onshape immediately bumps the revision and adds an asterisk. While this is very annoying, I can live with it. What I am having trouble with now is finding the latest release of a drawing. My current method is to click on the drawing (which pulls up the asterisk version) then click down the Version and History tree until I find the released version.
Is there a better way to find the latest release of a drawing? I am aware of the search function but without being able to specify the project (kept in a folder) I get tons of results which is just as bad. Well, I don't have tons of drawings just yet - but when I do have tons of drawings, it will be bad...
jmccormick Member Posts: 40 ✭
I just stumbled onto a solution - for my needs at least. When I open the drawing tab, RMB on the tab, and there is the option "Revision History". Clicking on that will bring up a dashboard that allows me to view the release, export the release, and even view the obsoleted release. This is also available for assemblies - but not for parts as far as I can see.
Thanks, Onshape for responding to my needs so quickly.0
When you open a document to edit it, the revision auto-increments because you're in a workspace, where your stuff is "work in progress", so there's no way to guarantee that the drawing hasn't been changed from what was released.
Tags - I assume you mean labels - are per user only so my labels might not match other user's labels.
For me - right now - I would be happy if I could filter the search by folder. I am not sure if that would benefit others though.
