Creating a loft feature
How do I create loft feature in Onshape?
I have attached a picture showing a loft feature in conventional CAD, how do I replicate it in Onshape?
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
The reason the loft looks the way it does is that (unlike the "conventional" CAD loft) it is modelled to look that way.
There is a single guide curve on the outside of the loft to which it is accurately conforming.
If you want to control the inside of the loft, simply add a second guide curve.
Are you trying to emulate the shape at the left in your original post, and if not, please indicate what shape you do want?
Be as specific as you can, otherwise it's a bit like going onto an auto website and asking "how do I drive a sports car?"5
You also need to prevent the loft from twisting, which may be a factor in the horrible result you somehow managed to get from Onshape.
There are video and text descriptions in the "Help" documentation section which will give you a starting understanding of how to address these issues.
I would encourage you to come back to this forum to clarify anything which remains unclear or problematic once you're had a look at those basic guidelines.
I cannot manage to duplicate your result.
I have attached a picture showing sections of a loft where 4 points are located on the circumference of the loft section. Is
What you need to do is to create two splines, one on the "Front" construction plane, and one on a "Side" plane, with the spline points "coincident" with the points, on one side of each profile in sequence. (Each spline is effectively an orthogonal projection, onto a construction plane, of the desired 3D guide curve)
Now extrude one of these splines as a surface to span the whole zone, and extrude the other spline "Up to" the first surface. You should now be able to pick the intersection edge to use as a guide curve.
And then by creating a third curve on the midplane (construction plane) through the centres of all the ellipses,
and then using this third curve as the path for a "sweep with guide curves".
This will require just a single elliptical profile, at one end of the path.
Now I create the Loft using the surfaces of the "Tools". (This way I don't have to redraw the sketch of the shape)
But when I try to use the sketched path as Guide Curves, the Loft fails.
Obviously I have never used a 'Loft' for anything production and am trying to figure it out!! Basically I am looking at hoods and fenders of cars for inspiration! Do I need to sketch the guide curve last? Could I "Use Edge" to recreate the sketched path so the new sketch pierces the profiles?
@dave_petit Well, I am getting closer! I sketched two guide splines on planes created at the vertices of the two 'tools'. Of course now both 'tools' are the same size, no scaling. I see the guide curves guide the vertices along it's path. I created one guide path as a 'Use' of the other. I was wanting to guide the whole profile (like a sweep), but yet have it get smaller along the curved path. Hmmm...seems like more construction entities are needed to do what I am thinking...
I was able to create this using a loft passing through sketches and matching vertices... so I'll keep trying!
Onshape uses the terminology "guide line" rather than guide curve, and stipulates (among other things, listed in Help, which anyone proposing to master lofting needs to read carefully)
A "center line loft" is a different beast from a conventional loft with guide curves, and a beast which Onshape does not currently offer.
Trying to create a loft from 2 x 8 sided polygons to 3 circles failed miserably on Onshape, (had to create the circles from 8 radii), however tried the same in Solid Edge with no guide curve (or sectioning the circles)- No Problem
The software will make up its own mind what "path" to use for the loft between sections: if you happen to like that path, no problemo; if no like, that's just too bad..
