Help with redundant code?
MichaelPascoe
Member Posts: 2,687 PRO
My code is very redundant, what would be a more efficient way to write this? I thought it may be a good place to use a function, but I'm not sure how to do it.
if (definition.groups[g].configScope == ConfigScope.EVEN_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || evenColumnPreset)
if (evenColumn)
if (definition.groups[g].transform || evenColumnMovePreset)
coordMatrix[u][v].origin = planeToWorld3D(tPlane) * (vector(definition.groups[g].dx, definition.groups[g].dy, definition.groups[g].dz));
rotTransform = rotationAround(line(c1.origin, c1.zAxis), definition.groups[g].obAngle);
if (definition.groups[g].scale || evenColumnSizePreset)
sizeX = definition.groups[g].sizeX;
sizeY = definition.groups[g].sizeY;
sizeZ = definition.groups[g].sizeZ;
if (definition.groups[g].configScope == ConfigScope.ODD_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || oddColumnPreset)
if (oddColumn)
if (definition.groups[g].transform || oddColumnMovePreset)
if (definition.groups[g].scale || oddColumnSizePreset)
}Learn more about the Gospel of Christ ( Here )
chadstoltzfus
Member, Developers, csevp Posts: 168 PRO
I agree with Caden above, we definitely want to keep this readable and also scalable. Let's say you wanted to perform operations on even columns specifically, I would keep those things outside of the function to allow you to do more in the main code body. I whipped up this function based on the code I saw above./** * Returns a map containing variables to be used for setting matrix options. * * @param group * @param coordMatrix * @param tPlane * @param c1 * @param movePreset * @param sizePreset */
function getMatrixOpts(group, coordMatrix, tPlane, c1, movePreset, sizePreset) returns map { var rotTransform; var sizeX; var sizeY; var sizeZ; var origin; if (group.transform || movePreset) { origin = planeToWorld3D(tPlane) * (vector(group.dx, group.dy, group.dz)); rotTransform = rotationAround(line(c1.origin, c1.zAxis), group.obAngle); } if (group.scale || sizePreset) { sizeX = group.sizeX; sizeY = group.sizeY; sizeZ = group.sizeZ; } return { "origin" : origin, "rotTransform" : rotTransform, "sizeX" : sizeX, "sizeY" : sizeY, "sizeZ" : sizeZ }; }
Then you can use it in those conditional statements (which are not redundant so I kept those out of the function.var opts; if (definition.groups[g].configScope == ConfigScope.EVEN_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || evenColumnPreset) { if (evenColumn) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, evenColumnMovePreset, evenColumnSizePreset); } } if (definition.groups[g].configScope == ConfigScope.ODD_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || oddColumnPreset) { if (oddColumn) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, oddColumnMovePreset, oddColumnSizePreset); } } if (definition.groups[g].configScope == ConfigScope.EVEN_ROWS || evenRowPreset) { if (evenRows) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, evenRowMovePreset, evenRowSizePreset); } } if (definition.groups[g].configScope == ConfigScope.ODD_ROWS || oddRowPreset) { if (oddRows) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, oddRowMovePreset, oddRowSizePreset); } } } cordMatrix[u][v].origin = opts.origin; rotTransform = opts.rotTransform; sizeX = opts.sizeX; sizeY = opts.sizeY; sizeZ = opts.sizeZ;That being said I can't really test this to see if it works with the rest of your code and I'm only human so let me know how this works for you.Applications Developer at Premier Custom Built
chadstoltzfus@premiercb.com2 -
Alex_Kempen
Member Posts: 258 EDU
If you wanted, you can do even better by combining if statement conditions together and setting a variable first to avoid redundant characters. Setting a variable is especially useful when nesting maps and arrays (like when using array parameters):const group = definition.groups[g]; const configScope = group.configScope; var opts;
You can also write predicates for common conditions:// can use group or configScope, whatever is easier/more convenient predicate evenColumn(group is map, evenColumnPreset is boolean, evenColumn is boolean) { evenColumn; group.configScope == ConfigScope.EVEN_COLUMNS || group.configScope == ConfigScope.ALL || evenColumnPreset; }<br>And lastly, you can set variables in your if statements to avoid copying and pasting the opts call multiple times.const group = definition.groups[g]; var runOpts = false; // if opts always runs, skip this var movePreset; var sizePreset; if (evenColumn(group, evenColumnPreset, evenColumn)) { runOpts = true; movePreset = evenColumnMovePreset; sizePreset = evenColumnSizePreset; } // use "else if" if only one statement needs to run per execution // i.e. if it's an even column, we don't need to check if it's also an odd column else if (oddColumn(group, oddColumnPreset, oddColumn)) { } // rest of else if conditions if (runOpts) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, movePreset, sizePreset<span>);</span> }As a final note, you could save even more lines by grouping presets into a data type which stores multiple values, like a map. You can also write tiny sub predicates to check individual conditions faster. For some examples of this, see line 301 - 335 of the extrude feature.
I hope some of this helps, or is at least useful stuff to know in the future.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots2
When you say "efficient", are you looking for less lines of code or for it to have less regen time?
It looks like the two if statesments for checking odd/even columns are the same... so those could be combined cutting out half of your code.
...Unless thats a mistake and they are different.
Is there a reason sizeX/Y/Z are not a vector?
That code could be changed to
sizeVector = definition.groups[g].sizeVector;
if the tPlane is always the same for the iteration over g you could calculate that transform before the loop and use it as a variable -> tPlaneTransform = ...
and then you aren't redundantly recalculating it during each loop.
Same goes for the line for c1.
By efficient, I mean not having the same code copy and pasted 4 times. Here is the whole loop, you can ignore the "presets" section:
As you can see, It is the same format each statement with slight variations.
for (var g = 0; g < size(definition.groups); g += 1) { //debug(context, definition.groups[g].dx == 0 * meter, DebugColor.RED); //debug(context, definition.patternTyp, DebugColor.RED); //___________________________________________________________ // PRESETS //___________________________________________________________ // var sizeX = 1 * inch; // var sizeY = 1 * inch; // var sizeZ = 1 * inch; var moveX = 0 * inch; var moveY = 0 * inch; var moveZ = 0 * inch; var moveA = 0 * degree; var evenColumnPreset = false; var oddColumnPreset = false; var evenRowPreset = false; var oddRowPreset = false; var evenColumnMovePreset = false; var oddColumnMovePreset = false; var evenRowMovePreset = false; var oddRowMovePreset = false; var evenColumnSizePreset = false; var oddColumnSizePreset = false; var evenRowSizePreset = false; var oddRowSizePreset = false; if (definition.texture == Texture.BRICK) { sizeX = 8 * inch; sizeY = 3.625 * inch; sizeZ = 2.25 * inch; evenColumnSizePreset = true; oddColumnSizePreset = true; } if (definition.patternTyp == PatternTyp.STAGGERED) { if (definition.groups[g].dx == 0 * meter) { if (evenRows) { moveX = sizeX / 2; println("no x input"); } } println("x input"); oddRowPreset = true; oddRowMovePreset = true; } //___________________________________________________________ // ------- //___________________________________________________________ if (definition.groups[g].configScope == ConfigScope.EVEN_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || evenColumnPreset) { if (evenColumn) { if (definition.groups[g].transform || evenColumnMovePreset) { coordMatrix[u][v].origin = planeToWorld3D(tPlane) * (vector(definition.groups[g].dx, definition.groups[g].dy, definition.groups[g].dz)); rotTransform = rotationAround(line(c1.origin, c1.zAxis), definition.groups[g].obAngle); } if (definition.groups[g].scale || evenColumnSizePreset) { sizeX = definition.groups[g].sizeX; sizeY = definition.groups[g].sizeY; sizeZ = definition.groups[g].sizeZ; } } } if (definition.groups[g].configScope == ConfigScope.ODD_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || oddColumnPreset) { if (oddColumn) { if (definition.groups[g].transform || oddColumnMovePreset) { coordMatrix[u][v].origin = planeToWorld3D(tPlane) * (vector(definition.groups[g].dx, definition.groups[g].dy, definition.groups[g].dz)); rotTransform = rotationAround(line(c1.origin, c1.zAxis), definition.groups[g].obAngle); } if (definition.groups[g].scale || oddColumnSizePreset) { sizeX = definition.groups[g].sizeX; sizeY = definition.groups[g].sizeY; sizeZ = definition.groups[g].sizeZ; } } } if (definition.groups[g].configScope == ConfigScope.EVEN_ROWS || evenRowPreset) { if (evenRows) { if (definition.groups[g].transform || evenRowMovePreset) { coordMatrix[u][v].origin = planeToWorld3D(tPlane) * (vector(definition.groups[g].dx, definition.groups[g].dy, definition.groups[g].dz)); rotTransform = rotationAround(line(c1.origin, c1.zAxis), definition.groups[g].obAngle); } if (definition.groups[g].scale || evenRowSizePreset) { sizeX = definition.groups[g].sizeX; sizeY = definition.groups[g].sizeY; sizeZ = definition.groups[g].sizeZ; } } } if (definition.groups[g].configScope == ConfigScope.ODD_ROWS || oddRowPreset) { if (oddRows) { if (definition.groups[g].transform || oddRowMovePreset) { coordMatrix[u][v].origin = planeToWorld3D(tPlane) * (vector(definition.groups[g].dx, definition.groups[g].dy, definition.groups[g].dz)); rotTransform = rotationAround(line(c1.origin, c1.zAxis), definition.groups[g].obAngle); } if (definition.groups[g].scale || oddRowSizePreset) { sizeX = definition.groups[g].sizeX; sizeY = definition.groups[g].sizeY; sizeZ = definition.groups[g].sizeZ; } } } // } }Learn more about the Gospel of Christ ( Here )
var opts; if (definition.groups[g].configScope == ConfigScope.EVEN_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || evenColumnPreset) { if (evenColumn) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, evenColumnMovePreset, evenColumnSizePreset); } } if (definition.groups[g].configScope == ConfigScope.ODD_COLUMNS || definition.groups[g].configScope == ConfigScope.ALL || oddColumnPreset) { if (oddColumn) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, oddColumnMovePreset, oddColumnSizePreset); } } if (definition.groups[g].configScope == ConfigScope.EVEN_ROWS || evenRowPreset) { if (evenRows) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, evenRowMovePreset, evenRowSizePreset); } } if (definition.groups[g].configScope == ConfigScope.ODD_ROWS || oddRowPreset) { if (oddRows) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, oddRowMovePreset, oddRowSizePreset); } } } cordMatrix[u][v].origin = opts.origin; rotTransform = opts.rotTransform; sizeX = opts.sizeX; sizeY = opts.sizeY; sizeZ = opts.sizeZ;That being said I can't really test this to see if it works with the rest of your code and I'm only human so let me know how this works for you.chadstoltzfus@premiercb.com
// can use group or configScope, whatever is easier/more convenient predicate evenColumn(group is map, evenColumnPreset is boolean, evenColumn is boolean) { evenColumn; group.configScope == ConfigScope.EVEN_COLUMNS || group.configScope == ConfigScope.ALL || evenColumnPreset; }<br>And lastly, you can set variables in your if statements to avoid copying and pasting the opts call multiple times.const group = definition.groups[g]; var runOpts = false; // if opts always runs, skip this var movePreset; var sizePreset; if (evenColumn(group, evenColumnPreset, evenColumn)) { runOpts = true; movePreset = evenColumnMovePreset; sizePreset = evenColumnSizePreset; } // use "else if" if only one statement needs to run per execution // i.e. if it's an even column, we don't need to check if it's also an odd column else if (oddColumn(group, oddColumnPreset, oddColumn)) { } // rest of else if conditions if (runOpts) { opts = getMatrixOpts(definition.groups[g], coordMatrix[u][v], tPlane, c1, movePreset, sizePreset<span>);</span> }As a final note, you could save even more lines by grouping presets into a data type which stores multiple values, like a map. You can also write tiny sub predicates to check individual conditions faster. For some examples of this, see line 301 - 335 of the extrude feature.I hope some of this helps, or is at least useful stuff to know in the future.
