Improvements to Onshape - June 1st, 2021
mfalkensteiner
mfalkensteiner Posts: 87 image
edited June 2021 in New in Onshape
Let’s kick things off in June with a new Onshape release - this time with a big focus on drawings! Let’s take a look!
GENERAL IMPROVEMENTS
CHANGE THE LOCATION OF A DOCUMENT FROM WITHIN THE DOCUMENT
To move an entire document to another project or folder, it is now also possible to do this directly in a document without leaving the document.
https://onshape.wistia.com/medias/y5t0pt3y81?embedType=async&videoFoam=true&videoWidth=640
HELP DOCUMENTATION REDESIGN AND IMPROVEMENTS
We have completely redesigned the help documentation to give it a modern look & feel. We also have a Glossary if you would like to explore a list of Onshape terms and their definitions. Furthermore, we have now added more links to the Learning Center, Helpful Tips, Warning messages and Troubleshooting messages to help you work through issues. Check out the new help menu here.
DRAWING IMPROVEMENTS
SECTION VIEW FROM AN AUXILIARY VIEW
In order to display complex geometries on drawings more easily and better, there is now the possibility to create section views from auxiliary views.
https://onshape.wistia.com/medias/ntwms0ubcs?embedType=async&videoFoam=true&videoWidth=640
SHOW/HIDE INDIVIDUAL SEGMENTS IN A DRAWING VIEW
To hide or show certain edges in a drawing view, there is a new option “Show/hide edges” in the view context menu. This serves to display complex geometries more clearly in order to avoid errors or misunderstandings. After the edges have been hidden, they can of course be shown again by deselecting them. This also works for inserted sketches on a drawing.
https://onshape.wistia.com/medias/jtj3ga84vr?embedType=async&videoFoam=true&videoWidth=640
SECTION VIEW WITH A SPECIFIED CUTTING LINE ANGLE
Instead of selecting two points in a drawing view to create an intersection line, there is now the option to define a specified angle under which the cutting line is created.
https://onshape.wistia.com/medias/5oxi4rjk42?embedType=async&videoFoam=true&videoWidth=640y
GROUPING OF CALLOUTS IMPROVEMENTS
Callouts can now easily be grouped with surface finish symbols, datums and weld symbols. Simply drag and drop the callout to group it or select the objects you want to group and select in the context menu "Group annotation".
Principal Technical Services Engineer, EMEAI
  • LyndeInnov
    LyndeInnov Posts: 9 PRO
    Gotta love those drawing improvements!
  • Great improvements! Thanks!
  • Alex_Pitt
    Alex_Pitt Posts: 77 PRO
    Very welcome improvements! Looking forward to a few more line colour & cross-hatch controls, but other than that, drawings are fast approaching perfection! Thanks for the incredible work Onshape team!
  • brucebartlett
    brucebartlett Posts: 2,148 PRO
    Hide edge will be very handy. Thanks
  • MichaelPascoe
    MichaelPascoe Posts: 2,943 PRO
    edited June 2021
    Excellent update. Thanks Onshape team!
    This can be marked as completed:
    https://forum.onshape.com/discussion/14659/hide-selected-lines-in-a-drawing
    RENDERCAD
  • lemon1324
    lemon1324 Posts: 230 EDU
    edited June 2021
    The changelog mentions "support custom feature tooltip images", does this mean things like the hole feature where the hole countersink parameters have images next to them?
    Edit: Looked at the documentation, found a section on Description Images on the UI page (https://cad.onshape.com/FsDoc/uispec.html), is it this?
    Arul Suresh
  • ilya_baran
    ilya_baran Posts: 1,273 image
    @lemon1324 Yes, it's description images.  Parameter icons like your screenshot has have been available for a while.
  • lemon1324
    @ilya_baran I must have completely missed custom parameter icons, last I remember was the thread from several years ago where naming things the same as the hole feature got the hole feature icons to show up.  Found the relevant bit of documentation now though, thanks!
    Arul Suresh
  • Some great improvements there, looking forward to putting them to use, especially the sections on aux views is long overdue.
    Was disappointed that the new
    doesn't have an option to specify section line as perpendicular or parallel to a reference edge/line on the drawing. This is going to make it very frustrating for use on parametric models and configurations with variable pitch
  • theo_richardson
    theo_richardson Posts: 4 PRO
    Thanks! Hide show edges & drawings improvements. Help is also great for us.
  • Barry_van_Wijk
    Barry_van_Wijk Posts: 46 PRO
    Perfect! I really needed hard the  Hide show edges, thank you!!!
  • shawn_crocker
    shawn_crocker Posts: 1,033 PRO
    Hide show drawing edges is better than not having it.  still seems slightly awkward.  Still wish we could just hide an entire part or assembly from the view without having to create so special display state in the model.  If the model is already released...it make for a headache of unnecessary revision bumps just to get things straight in the drawing.
  • danny_payne
    danny_payne Posts: 42 ✭✭
    I really like the updates to the drawings. The angle cut lines and hiding specific lines is great.
  • MichaelPascoe
    Show/Hide edges works very smoothly.
    RENDERCAD
