Adding a drawing sheet template
I have made a custom drawing sheet with a title block that I want my students to use. Is there a way to add this dwt to our education enterprise so that they can choose it?
  • Member, csevp Posts: 19 PRO
    Documentation for how to do this can be found in the Onshape Help Center for Custom Drawing Templates. If you want to import a template as a dwt, import the template into your enterprise and find it inside your Onshape content when you are going to create a new drawing.
