Assembly: Short way to connect Parts
nicola_malagnini
Member Posts: 35 EDU
hello,
as you can see in the picture, i need to connect the headlight ''1'' in the correct place ''2''. headlight ''1'' it's made up of 4 parts, becouse i have to respect the correct colors.. so, there is a short way to connect ''1'' with ''2'' using only two mates (like in the picture)? or the only way it's to connect each parts with two mates for?
very thanks
very thanks
Alternatively, you could group the parts right now and use a single fastened mate.
Very Thanks!
