Assembly: Short way to connect Parts
nicola_malagnininicola_malagnini Member Posts: 35 EDU
hello,
as you can see in the picture, i need to connect the headlight ''1'' in the correct place ''2''.  headlight ''1'' it's made up of 4 parts, becouse i have to respect the correct colors.. so, there is a short way to connect ''1'' with ''2'' using only two mates (like in the picture)? or the only way it's to connect each parts with two mates for?
very thanks
  • alnisalnis Member, Developers Posts: 453 EDU
    I would recommend making those parts into a composite part in your part studio (not closed to preserve existing colors), then inserting the composite part into the assembly rather than individual parts. Then, you should be able to mate it with a single fastened mate.
    Alternatively, you could group the parts right now and use a single fastened mate.
  • nicola_malagnininicola_malagnini Member Posts: 35 EDU
    you are speaking to make a composite part in my part studio, using a boolean?
    Composite part feature. Press alt C to search, type composite, it will highlight in your toolbar. Then, in the feature, you can press the ?  in the bottom corner of the panel/popup to see the help/documentation for how it works.
    It works!
    Very Thanks!
    No problem! Happy to help!
