Newbie question on dimensions for export
skyvoyager
Member Posts: 1 ✭
I know this is a newbie question...Sorry!
I have units set to inches in Onshape. When I export parts via STL and import them into Cura or Simple3D, they come in as mm (for instance, a 2 in x 2 in x 2 in cube comes in as 2 mm x 2 mm x 2 mm).
What am I doing wrong?
Thanks!
Thanks!
Check the settings in the programs where you are importing, maybe there is possibility to choose units. It's just scaling.
Mike
What this means is that they are just numbers, with no unit specified within the file, hence it makes no difference what your export settings are: it is only the import package which can assign units.
except when, just for fun, I exported the STL and selected millimeters as my unit to export. When I opened the new file with the printer software the model was the correct size. If the previous statement were correct (and it seems like it would be the best and easiest solution) then the files should be identical no matter what unit I select when I export.
What does my selection mean when I select units for STL export and how do the selections modify the dimension data exported?
