Make Drawing "Page" bigger?
I'm trying to make a drawing of my creation, but I don't know how to make it big enough to export the whole image to PDF.
Can anyone help me?
I'm sure it's easy, but I don't have the right words/search terms to find it.
Thank you!
Can anyone help me?
Thank you!
https://cad.onshape.com/help/Content/drawings-sheets.htm
When you'll go to export it, you'll want to right click on the tab at the bottom and select Export...
Also, if you're making a sort of box that will slot together from each side, I would recommend checking out the Laser Joint and Auto Layout custom features:
FeatureScript Laser Joint | Laser Joint (onshape.com)
FeatureScript Auto Layout | Auto Layout (onshape.com)
