ARRAY VARIABLES
shawn_crocker
Member, OS Professional Posts: 1,034 PRO
I'm having a hard time creating an array that has a dimensional size defined by another variable
var partCount = size(evaluateQuery(context, definition.sheetMetalParts));
var flatSizes = [partCount];When I try to store things into flatSizes, [0] dimension takes a value but when the code loops back to store something in [1], I get a "Array index 1 out of bounds.". It feels like I not defining the array size properly.flatSizes[i] = getExtents(boundingBox, 3, inch);That is how I'm trying to store the map values. I'v been searching and am not finding clear answers on this one. 0
You're currently making an array containing the variable partCount. Accordingly, flatSizes always contains a single element, so it always has a size of 1. To make flatSizes properly, use makeArray instead.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots1
FRC Design Mentor - Team 1306 BadgerBots1 -
@Alex_Kempen your a life saver. Thanks again.0
