Query specific edges
shawn_crocker
Member, OS Professional Posts: 902 PRO
I'm looking for a way to query all the edges of a surface body. I'm hoping there is a way to filter only for edges that have two faces attached. I'm sure I read this somewhere but I am not able to find where it was.
Alex_Kempen
Member Posts: 255 EDU
qOwnedByBody can give you everything owned by a body. The aptly named function edgeIsTwoSided will then let you filter for the edges you want.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots2 -
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
isEdgeTwoSided() is a test if you already have an individual edge, to query two sided edges you may use qEdgeTopologyFilter()
2
@Alex_Kempen
Thanks again. I haven't had time to implement them yet but now I know what I should be using.
