How do I use a mesh (downloaded .STL file) in an assembly?
Trying to create an assembly, however, it requires the use of an .STL file I found online, when I imported it, it came as a mesh (as expected), but when I tried to use it in an assembly, it doesn't show up. Do I have to change the file format of the .STL or is there a workaround?
https://forum.onshape.com/discussion/11068/mesh-in-assembly
Onshape, Inc.
