PSA: New additions to the FeatureScript Standard Library
Alex_Kempen
Member Posts: 255 EDU
If you aren't in the habit of regularly browsing the Standard Library Source or the Standard Library Documentation, you might have missed the addition of two new functions to the Onshape standard library in the latest Onshape release, isQueryEmpty and areQueriesEquivalent. (I guess they weren't deemed worthy of a mention in the release notes?)
isQueryEmpty is particularly notable since it performs better and is more streamlined than the old method of using evaluateQuery(context, myQuery) == [] to check for empty queries. So it's definitely something worth using moving forward!
Onshape, Inc.
