I'm after a new laptop budget is low do, what is the laptop requirements for onshape? Thanks
scott_denne
Member Posts: 4 ✭
in General
- I'm after a new laptop budget is low do, what is the laptop requirements for onshape? Thanks
Optionsalnis Member, Developers Posts: 449 EDUWhat scale of projects are you working on? If you are just doing simple parts and small assemblies as a hobby, you can run it on just about anything, even cheap chromebooks.
For bigger models, you'll want a more powerful laptop. Personally, I ran it on a computer with an i5-3337U, 8 GB of RAM, and no dedicated graphics for a long time and designed a 1,800+ part robot using it. However, I now have a computer with an i5-10210U and it runs great. It would be even better with a graphics card.
Here is how I'd order priorities:- Something recent/new
- Graphics. Iris instead of UHD for Intel processors, AMD seems to always be pretty good, any of the M1 MacBooks are great. Dedicated graphics such as Nvidia cards will give very good performance.
- Processor (more recent is much more important than i7 vs i5 vs i3)
- Memory is not too important for Onshape, but if you have many large models open you'll need more
- Storage - Onshape does not require local storage, but try to get an SSD if possible (even if it's much smaller) since it will make your computer much more responsive
- "Workstation" graphics card (e.g. Quadro) instead of "gaming" graphics card (e.g. GeForce). Gaming graphics cards give much better performance for the money.
- ECC memory
- "Workstation" processor (e.g. Xeon) instead of "consumer" processor (e.g. i5)
It will give you a good sense of whether the computer is compatible and how fast it will be. 100 million triangles & 50 million lines per second is good enough for all but very large projects, but more will always give a smoother experience.Student at University of Washington | Get in touch: contact@alnis.dev | My personal site: https://alnis.dev0
Non-factors (provide no advantages whatsoever):- "Workstation" graphics card (e.g. Quadro) instead of "gaming" graphics card (e.g. GeForce). Gaming graphics cards give much better performance for the money.
- ECC memory
If you can, see if you can get someone with the laptop model you want to run the benchmark: Compatibility check (onshape.com)It will give you a good sense of whether the computer is compatible and how fast it will be. 100 million triangles & 50 million lines per second is good enough for all but very large projects, but more will always give a smoother experience.
I 100% agree with @edward_petrillo - go to a physical store and run the benchmark + test drive a CAD model you could see yourself working on to see if it's good enough.
Test model - Onshape design competition entry that won
Test model - my high school robotics team's robot from about 1.5 years ago - 12788 Ultramain 2019 | Ultramain (onshape.com)
Chromebooks are the best bang for the buck for Onshape, and I've heard that the new M1 MacBooks are absolutely incredible for their price if you can afford one (but they do not have the same price floor as Chromebooks).
