Is Merge to Main necessary?
I have been testing some branching and merging in some recent parts. I currently have a "document" that has changed radically since branching from "Main". Is it required to merge the final design back into the "Main" branch or is it Okay to leave the final branch as-is? If left without merging to "Main" how do others know which branch to reference?
Can I successfully merge a totally different design back into the original "Main" branch without extensive errors?
As for merging back to main after a lot of changes, I suppose it depends what exactly you’re intending to do with Merge. If you take your branch entirely and ignore other branches, there won’t be any errors. If you depend on some object that another branch deleted, there will of course be errors.
I hope this is right, I may be off on a detail or two of what merging implies.
www.virtualmold.com
www.virtualmold.com
I use Branching to explore ideas, iterate for FEA, etc. However, once I've made final selections, I make sure to merge the correct branch into Main, make a Version in the extra branches at that point, and delete the branch workspaces. I'll often name the merged dead-end branch "FEA exploration - MERGED to Main" or something. I'll name the other dead-end versions with a useful name as well. You can always come back later and branch from those Versions to create more Workspaces if desired.
Then, I try to make sure that Main is the only live workspace, and the only workspace that Releases come from (if you use Release Management).
If you have several Workspaces (if each Branch has a live workspace) then every 3 weeks they all get updated - and it's no longer as easy to see which is the most recent or active Workspace (since during Onshape updates, they all get updated).
Hope that helps!
