PSA: New additions to the FeatureScript Standard Library
Alex_KempenAlex_Kempen Member Posts: 258 EDU
edited June 2021 in FeatureScript
If you aren't in the habit of regularly browsing the Standard Library Source or the Standard Library Documentation, you might have missed the addition of two new functions to the Onshape standard library in the latest Onshape release, isQueryEmpty and areQueriesEquivalent. (I guess they weren't deemed worthy of a mention in the release notes?)
isQueryEmpty is particularly notable since it performs better and is more streamlined than the old method of using evaluateQuery(context, myQuery) == [] to check for empty queries. So it's definitely something worth using moving forward!
  • caden_armstrong2caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    Good catch!
    For a more detailed breakdown you can always visit our Change log: https://www.onshape.com/en/changelog/
    Onshape, Inc.
  • Alex_KempenAlex_Kempen Member Posts: 258 EDU
    @TimRice You're not wrong, although it seems that these functions in particular didn't quite make it into the changelog, which was why I decided to post about them.
  • brooke_spreenbrooke_spreen Member, Developers Posts: 115 ✭✭✭
    B)
    Design Engineer | Anerdgy AG
