Edge length of evaluated face?
MichaelPascoe
Member Posts: 2,774 PRO
I'm trying to measure the boundary edge of an evaluated face. When using evFaceTangentPlane, if the face is not square, the evaluation will project where the face should be. I can place a plane on the invisible edge shown below with evFaceTangentPlane. However, I'm not sure how to get the length of the invisible edge.
If I use opCreateCurvesOnFace, I can see the invisible boundary curve in red, but I can't measure it.
Is there a way to measure the invisible boundary edges calculated by evFaceTangentPlane or something similar?
For anyone else who may need the unseen boundary edges of an evaluated face, here is what I used:
var xSplineResolution = 10; var ySplineResolution = 10; var xSamples = []; var ySamples = []; var xLength; var yLength; for (var i = 0; i < 2; i += 1) { var resolution = i == 0 ? xSplineResolution : ySplineResolution; for (var k = 0; k < resolution+1; k += 1) { var parameter = i == 0 ? vector(1 / resolution * k, 0) : vector(0, 1 / resolution * k); debug(context, parameter, DebugColor.RED); const plane0 = evFaceTangentPlane(context, { "face" : surface, "parameter" : parameter }); if (i == 0) { xSamples = append(xSamples, plane0.origin); debug(context, plane0.origin, DebugColor.RED); } if (i == 1) { ySamples = append(ySamples, plane0.origin); debug(context, plane0.origin, DebugColor.GREEN); } } } opFitSpline(context, id + "fitSplineX", { "points" : xSamples }); opFitSpline(context, id + "fitSplineY", { "points" : ySamples }); xLength = evLength(context, { "entities" : qCreatedBy(id + "fitSplineX", EntityType.EDGE) }); yLength = evLength(context, { "entities" : qCreatedBy(id + "fitSplineY", EntityType.EDGE) }); debug(context, xLength, DebugColor.RED);Learn more about the Gospel of Christ ( Here )
