Creating a 3D path to sweep with a circle to create a tubular steel handle
I can't quite figure how to draw paths in three dimensions with bend radii so that I can sweep it with a circle to create a bent tube. Can anyone help? Thanks.
https://cad.onshape.com/documents/3bf490a882faa9d9277564e2/w/ce0c1e8142c4772a56d0070c/e/458edd52bcbd22329a442959
  • Anthony_O_ConnellAnthony_O_Connell Member Posts: 7
    The 3D Fit Spline seemed to work quite well once I created a composite spline from the different line segments. Thanks for the help!
