円弧が閉じれません。arc cannot closed
Toshimichi_Oda
OS Professional Posts: 53 PRO
in General
スケッチで円弧の自由端点を もう一方の端点までドラッグします。
円弧が見えなくなります。
円弧が閉じて、円となるべきです。
またスプラインも閉じることができません。
I drag one free end of arc to another end in sketch.
Then the arc is invisible.
I expect it will be closed and become a circle.
And I cannot close spline :
https://forum.onshape.com/discussion/9875/how-to-close-an-existing-spline
> HOW TO CLOSE AN EXISTING SPLINE ?
円弧が見えなくなります。
円弧が閉じて、円となるべきです。
1
もしこちらの手順で出来なければ、スケッチの実際の手順を教えてもらえますか?
Could you do a demo of creating closed spline as the OP is trying to do? I have not done these and do not follow the first option of Jake's instructions.
"You can drag one of the endpoints over the other endpoint to lock them together (or just create a 'coincident' constraint between the two). You will then have a closed spline that is probably discontinuous at that one point. To fix this you could draw a construction line between the two handles, and then set a coincident constraint between the discontinuous point and that construction line."
https://forum.onshape.com/discussion/9875/how-to-close-an-existing-spline#:~:text=You can drag,that construction line.
I just retried my instructions and you are correct that they don't work...
I think the best way to go about this is to just sketch a new spline on top of the old spline, making sure to close it up
I remember that I was able to close spline too. But now cannnot.
I guess that arc cannnot be closed for the same cause.
再試行ありがとう。私も以前はスプラインを閉じることはできたと思う。
同じ原因で円弧が閉じれないと私は推測します。
yes, in both cases it is necessary to draw it closed. they do not allow dragging to close. Makes sense. If you need a circle or closed spline just draw it as such.
