setback fillet
henry_feldmanhenry_feldman Member Posts: 135 EDU
Has anyone gotten the setback fillet plugin to do anything? It won't let me select a corner/edge actually anything. I have no idea if it works or not once you select since it won't let me click on anything. Are there any special things you need to know to use it.
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    Are you talking about the FS I wrote here? If so, keep in mind that per the prerequisites section in the info tab there needs to be an existing fillet. The FS just converts a regular corner fillet into a setback fillet.
